vcSendSignalStatement
Send Signal statement sends a simulation signal, i.e. triggers a signal behavior, with a given value.
SelectedComponentvcComponentRWGets or sets the component that owns the signal. Must be a static component.
SelectedSignalvcBehaviorRWGets or sets the signal behavior to trigger. Must be either Boolean, Integer, Real or String signal.
ValuePropertyvcExpressionPropertyR
Access expression value via vcExpressionProperty, E.g., ValueProperty.Value
Gets an expression property which is used to generate the value for the signal.
